- Joined
- Oct 10, 2004
- Messages
- 3,583
- Reaction score
- 63
More information from Vines: http://blog.vinesbmwbikes.co.uk/2012/07/bmw-f-700-gs-bmw-f-800-gs.html
The front pads on my F650GS only lasted 6000 miles--if I was living in a hilly area like the Alps, they wouldn't last that long, so adding a second disk/pads set makes some sense.
Much of the higher BHP on the F700GS (see F650 vs F700 power curves below) is gained at the extreme top end of the rev range.
The F700GS gearing is lower as well (17:42 sprockets vs 17:41 on the F650GS twin) which will help acceleration at the expense of higher revs at motorway speeds. Pity the gearbox ratios weren't widened so that you could have lower first and second whilst keeping the higher gears. The F700GS now requires the use of what BMW terms 'premium fuel' which is RON95. An optional engine map is available to run RON91 but will undoubtedly lower the power slightly. If you see a reference to RDC that's the tyre pressure monitor.
The Osta Grey matt metallic F700GS looks cool.
Pity BMW didn't go further developing the F800GS. Is this really BMW's answer for the next three years to the Tiger XC? I can't honesty say ASC or ESA excite me. The front forks are still not adjustable.
The speedo is still analogue (I love the ability on the Tenere to switch the display to km when I'm in Europe or Africa). Both bikes are available in a restricted 48HP version for new riders. Both are available with lowered suspension for partially heighted riders.
All BMW bikes from MY13 production (officially starts August) will have ABS as standard. Launch and limited availability expected September 2012.
Tim
Tim
You will end up a power Ranger.
