New Hi power radio
Dependant on quality these seem a bit pricey,also as its vhf you wont be able to talk to anyone with a pmr radio.I have had several radios for bike to bike use including Puxing,Weiwei and feidaxin,I`m currently using a Wintec with 2w and this seems to be a nice little radio.Check out Ebay for a choice of cheap radios,remembering you need UHF freq with 12.5 steps.Most vhf handhelds are 5w and uhf versions 4w.If you dont fancy buying from China have a look at Intaride
http://www.intaride.com/business_radios.html
but these are not as cheap as the Ebay versions.
Its only worth getting your own frequency(via ofcom)if there is a lot of you using radios so you can share the cost.When we are out and about we very rarely get anyone sharing a channel and if it happens you are out of range in a few mins.
Well, not anyone using UHF PMR446.
These radios will be under the UK General License, and for info the frequencies are;
VHF Low Band VHF Mid Band
86.3375MHz 164.0500MHz
86.3500MHz 164.0625MHz
86.3625MHz
86.3750MHz
77.6875MHz
VHF High Band UHF1
169.0875MHz 449.3125MHz
169.3125MHz 449.4000MHz
173.0625MHz 449.4750MHz
173.0875MHz
173.0500MHz
