Bob at the VFR forum
Copied below is a feedback report from Bob at the VFR forum about the S1 lid, gives it the
Schuberth S1 Helmet
Took the S1 out for a test ride this morning.
The helmet is very comfy and the peripheral vision is excellent, much better than my AGV.
It is much quieter than the AGV, rode it for a few miles without earplugs and the noise was not uncomfortable, I reached speeds of 85ish. The instructions for the helmet do say that it will be noiser on a faired bike than on an unfaired one, depending on how the screen deflects the wind blast. If it hits the rider around the neck line then the noise will be greater. This I found to be true, I get wind blast around the shoulder/neck area. I tried raising my height a little so the blast hit me in the lower chest area, the noise levels decreased significantly, at 80MPH it was extremely quiet. Therefore, this helmet will be at it's quietest on a naked bike. As I said earlier, it was not particulalry noisy at my normal ride height, I felt I could ride some distance, at speed, without earplugs. I could never have done this with my AGV. With my moulded plugs in I could hardly hear any noise at all at high speed. There is an additional Noise Deflector that is available as an optional extra, I should imagine if this were fitted one would never need to use earplugs again.
Both the clear an the tinted visors have an anti-mist treatment applied to them. It was fairly cold when I went out first thing, and try as hard as I might I could not get the visor to mist up. Should I find that the coating deteriorates with time a breath guard is available as an optional extra.
The drop-down tinted visor (80% grey tint, a 60% brown tint is an optional extra) is very good and easy to operate. When I inspected the visor in the shop I didn't think it was particularly dark, so when I got home I compared it to my Rayban's and I would say they are about the same level of tint. I rode into some direct sunlight this morning and found the visor performed as well as any sunglasses I've used.
The clear visor is a very good fit, you can see it touching the seal all the way round. With my AGV I always had a cold draft blowing into my eyes, not so with this helmet. The clear visor is a doddle to remove with it's quick release mechanism. However, the tinted visor is a bit fiddley to take off and put back on, but then there should be no need to take it off too often.
The ventilation system is also very good. With the top inlet vent closed, the exhaust vents will still extract stale air (CO2) using a venturi action, this could be felt ever so slightly as a very light draft at the top of the helmet. With the top vent open I could really feel the flow of air around the top of the head, therefore it should be very cool on hot days when on the move.
The chin strap on this particular helmet is of the push-button quick release type. I'm not used to this and find it a bit awkward to fasten. This will probably get easier with practice. Reading the manual it turns out that the helmet is also available with double D-ring fasteners. The manufacture can replace the fasteners with the alternative type if required, for now I will just try and get used to it.
The helmet shell is a little larger than most helmets.
Overall, I am very pleased with it. I managed to get the shop to knock £39 off the marked price, so I got it for £290. No doubt if I'd waited a while I could probably have got it cheaper, but I'm an impatient sod, and all the Schuberth dealers are miles away, so I just bit the bullet and bought it!
Bob
