will be fitting a nn autoswitch over the chrimbo break ,the instuctions are a slightly unclear(to me anyway)as to the colour of the trigger wire from the indicator relay ,can anyone help ,the bike by the way is a 2004 1150gsa thanks in advance chaps
Reply #10 you will see how I did it without cutting the loom.
A much better and neater solution. Well that is until your flasher relay packs up and you have to solder the wires on again. A very complex flasher relay if you ask me.
I have had it like this for nearly a year and no trouble so far.
