1150 gs 1999 non abs, out and about to day no issues, then started up and noticed no indicators dash lights or running lights. Pulled all the relays all seem ok and ideas other than pushing it off a cliff!!? Thansk
Put your finger on the small yellow relay (load relief relay). You should feel it operate when you turn on the ignition.
The relay controls
lights
indicators
horn
heated grips.
if you can’t feel it operate, then there is a fair chance it has failed. If you think it has failed, then pull the horn relay and stick it in the Load relief relay position and see if you get all your electrics back (except the horn of course).
