No oil or water temp idiot lights on my F650 Funduro
Kenny
Trustworthy Scouser AND
Moderator
Moderator
Toxteth scouser, made good ..now hiding on Wirral
Indicators/neutral,all fine. When I turn ignition on the oil and the water temp don't illuminate.
Is this a known problem ( i.e. simple fix ) for this before I attack with venom ?:D Power is to the oil switch and water pump if I hook it up
with a seperate power source from the battery.
Found out why there was a slight drip from the float bowls...should be a long taper on those drain screws !!:blast
Replaced the oil sender switch ( from Motorworks )..happy days now. Old switch was a 22mm and new one is a 24mm...so you will need a 24mm spanner as socket access in very VERY tight !
Oil light now works and tested ( grounded ) the water switch, which apparently doesn't come on with the ignition, just when low water.
