Nolan n101 help
  • Thread starter Thread starter custard
custard
Hi
Has anybody ever had a Nolan Classic n101?
I have a question, if it has red levers under/each side of the chin piece with the words SMART LIFT does this mean that the chin peice can be lifted with one hand???
Yes, but only the left side lever can be used one handed. For some reason, if you operate the left lever, it also operates the right lever and the latches release. However if you try to release with only the right lever, then it won't work.
At least that's how mine works.
Regards,
Glenn
Glenn is spot on.
Whatever you do, don't get an N102. It's rubbish compared to the N101. The N103 is worse than the N102... :augie
Achim
