Non abs brakes
gsa matt
Member
Kerry Ireland
Hope this is in the right place lads!
Ok brought a 2001 gs 1150 last week! Brembo calipers! Went on to motoworks and ordered many things including front and rear braided lines! Went to fit them tonight and looked at the calipers I only have one bleed nipple on left caliper! Right caliper has a long kinda thing on it! Said I better hold off and ask for help! Am I in trouble or is this OK?? And how do I bleed??? Thank :thumby:
Both calipers should have normal bleed nipples. Can you post a picture of the long thing on it?
Edit: I thing the 2001 earlier models did have a weird part where the nipple should be. I should imagine this could be replaced with a conventional nipple, but best wait for a 2001 owner to confirm.
Long thing is for factory fill , just take it off and replace with regular bleed nipple same one used for clutch fill
That's great lads!! Thanks! Ya I have one of them factory fills on my right caliper! Will be removed later and replace with normal nipple! :thumb
