I have a heated waistcoat with a cigarette lighter male connector. If I remove the red tip it reveals what appears to be the right male connector for the female accessory port on the WC GS. Is that correct?
I'm unclear what sized plug your jacket has but if it's not the right size to fit the bike's plug, you could change it to a 'Hella' plug which will fit.
Hi, yes, pull the red tip off to use in the dash socket, it should be ok on the can us but it occasionally may trip depending on the sensitivity of the waistcoat/bike as its on the limit, if I were you I would try it first but I recommend a simple fused connector from the battery.
What you have is quite common with the red cap on its a standard cigarette lighter plug which will fit a standard cigarette lighter socket. Removing the red cap exposes a male din plug which will plug in to your socket which is a female din socket.
