Has anyone had any success in loading O/S type maps onto mapsource?
I've just been playing with my garmin oregon 550, and it appears to have a routing function- essentially you select a point, which the unit stores and "joins the dots" as you go along- i figure just put a point at each major change of trail direction or junction. seems quite simples.
Now it does this using the O/S maps on the oregons's little screen, which makes putting a route together quiet easy, but it would be even simpler if i could do all this on the laptop and then put it onto the oregon, or just use the oregon through the pc so i can have more detail up- to help work out where i want to go next.
Which if you've tried using a standard gps isn't quite so easy when you can't see the detail on a reduced scale map with a small field of view.
Has anyone else found a solution for this??
Nathan
Nathan
) can be clearer ?
