It's gotta be those earsI hear everything![]()
Further to the above .... just make sure you do isolate the problem and get it fixed. You don't want the engine cutting out halfway round a bend or on an overtake
IF the Hall Sensor packs in the fuel pump will not work otherwise it would fill the cylinders with petrol, with possible theatrical results![]()
Absolute 100% utter bollox x10.![]()
I think you're taking the MickyBack to you Sir
From a top time served BMW Technician, still there doing it at one of the biggest dealers in the country, done all the courses, even sent to Spandau to 'rub shoulders'
"The motronic unit briefly earths the fuel pump relay on initial ignition on to prime the system. From there on it relies on a crank sensor signal eg hall sensor. Doesn’t cut power. It doesn’t provide the ecu with a signal to switch the pump on. It’s the Ecu that provides an earth for the fuel pump relay"
No Hall Sensor = no fuel pump
I think you're taking the Micky![]()
Back to you Sir
Otherwise gone quiet on here
I'll say again.. Absolute rubbish.
It'll now stay quite from me, as i have a business to run repairing custoners BMW's..![]()
I don't think so kid
.... and we all know Tim's expertise on all things mechanical on King Rats 650 gearbox sprocket thread ... "They all do that"
You missed the sarcasm.
Some of us have spent a life as mechanical engineers while you spent yours nicking speeding bikers![]()
