Oh shit! moment …
OldCroc
Welton nr Lincoln, England
Whilst rinsing off the salt after yesterday’s ride I found this. Don’t want to think about what could have happened …!
Both bolts had evidence of thread lock but still came loose.
i don’t know much about thread lock so any suggestions as to which one to use as I understand they come in different strengths - much appreciated!
a couple of drops of Blue NOT slathered in it
Also Torque them with a known good torque wrench!! AND when torqued get a tippex Marker and mark a line from the centre of the bolt outwards and onto the frame in a way that you can see it with just a glance
They are known as Witness marks and were used in the factory
What would have happened? You would have started to notice the footrest becoming more and more wobbley or the sidestand moving more than it should!
Do a check around that everything is tight and satisfy yourself that nothing else is loose
Witness marks are handy because you can immediately see if a line is broken and like the hands of a clock rather than a straight line
perfect 👍
