Has anyone else noted that their oil cooler is offset in relation to the frame that goes around it? The frame is the one which you can see when the beak is on, and the beak attaches to by the front screws. The lack of clearance is as the frame bends to keep away from the cooler. I'll try and post a picture of the area later.
While trying to fit an oil cooler protector I noticed there is no clearance on the right (as you look at it from the front, or the oil filler side) and 3-4 mm on the other. The clearance, or lack of, can be seen with the beak on by the way. Other new 12Gs looked at today are also the same.
So are they all like that sir?
