Oil filter tool spinning!!!
dunnie
On the road, for now:-)
I do apologise for posting on here alot recently but I'm getting the old 1100 back on the road. Today's activities were to replace my oil filter, yes I do have the correct tool..... However it's spinning whilst trying to undo the darn thing. I've only used the tool twice before.... Any ideas on dealing with this dilemma? I'm trying to pack out the insides of the tool abit to see if that might help, I take it she will undo anti clockwise, can't remember from last time??
Thanks, Nigel :thumby:
degrease it mix up some quickset epoxy and undo, others say a sheet of sandpaper:beer:
Yes anti clockwise from below to Undo
Two self tappers drilled and screwed through the filter work as well
TIP OF THE DAY
NEVER Use those Schite Hi-Flo filters!!
Line the filter tool with half a sheet of sandpaper or wet and dry and whack it onto the filter. :thumb2
No messing, or mess, and if it doesn't work the bike is still rideable to someone who can remove it.
Unlike using self tappers in the filter which means you're not riding the bike anywhere if they don't work . :D
There's your £12 worth on its own.:thumb
...or it would have been if you'd subscribed.
May the gods scald his spanner hand with burning oil! :rob
Mind you he's been fecking with that oil filter so long it'll be ice cold in Alice by now.:blast
+ 1 for steppers
that method hasn't failed me yet
+ 1 for steppers
And a +1 from me too :thumb
And when you get it off, oil the new seal and just fasten it hand tight plus 'a bit' - too many people lean on a big socket wrench and way over tighten filters.
It's off with thanks
It's off, new ones on now but I'll loosen and tighten by hand, thankyou.
Because you can't actually get your hand onto the filter, I use a socket wrench with the head of the wrench in the palm of my hand (the socket extension between first and second fingers) to hand tighten the filter. Then another quarter to half a turn or so using the wrench.
It's kind of a 'feel' thing.
Obviously check for leaks after finishing :thumb
tighten by hand then plus 3/4 turn The 1200series filters are marked with this in french! but not english
I think the torque was 11nm
The problem is people think, "that's not very tight, i'll give it just a bit more".
I barely tighten a new filter, and never had a single leak.
