mickskelly
I noticed a little clutch slippage. So I ordered a new friction plate and started stripping (the bike) to get to the clutch. Such an awful job to get the clutch out on these babies
When I got the clutch out there was still a fair bit of meat left on it but it had gotten some oil on it which i believe was causing the problem. Oil looked like it was getting in through the push rod. There's a little material type seal on the pushrod. It doesn't look like its job is to seal from oil though. It was hard to see where the oil was leaking from. I've just read that oil can leak from the clutch slave cylinder and/or the gearbox. If it's a seal on the gearbox that failed then does that need to be stripped?
As an aside, I'm really pissed off with this thing. The only clutches I've ever done involved opening 6-8 bolts on a side casing. My honda biking friends are in utter stitches laughing at the sh1t I've had to go through to do what should be a simple job. I was just about to go on a trip around europe on it, but have to take the k-GT instead. I'm only glad it didn't fail me on the road.
