Thinking about replacing my clutch before the big trip.
Currently the bike has around 80,000km (50,000miles) on the clock, works OK so probably still some clutch left. But there could be almost the same much mileage from the trip added, so what do you reckon - should I replace the clutch before leaving? Or better to go on the "if ain't broke don't fix it" route?
Other thing I'm worried about is the dryness of the splines, that can turn out to be a show stopper at one point of the longish journey following with weeks of (more exotic) parts-waiting etc import paperwork hassle in the middle of nowhere. So maybe indeed it's better to replace the clutch and re-grease the splines whilst I'm there(?)
If yes, what should I replace? I.e. is it better idea to replace the whole clutch as a kit (friction place, pressure plate, spring etc) or it's waste of money and better to just go for the spring and friction plate?
Also I know there should be (much cheaper) aftermarket clutch plates available for 1100s too (apparently fits for some models of (BMW?) cars), are they worth it per long term or is it better to get the OEM-only bits?
Any advice and experiences on the issue highly welcome!
Cheers, Margus
Cheers, Margus
