dcd87
Good work! And you found a use for those weight platesI do a bit but I don't think I would have taken this on. Sorts out the men from the boys
(actually not really PC that is it 'cos I don't know, you could be a woman.... that dryer in the corner )
No that’s the wife’s! Haha.
Thanks for the help everyone. So far it looks good. Had it run up to temperature and so far no leaks. Just need to get a decent run it to feel confident I have built it back up right.
I think I need to drop the drive shaft out again as it looks like the bottom need (closest to final drive) gaitor isn’t seared correctly. I do t want to get any water ingress into there as it all looked clean, dry and corrosion free before I started probing!
