Checking the oil level is NOT a black art. It is very simple.
First thing, get out your owners manual and read the section on checking oil level. In summary it states.
1. get engine to operating temperature (3-5 bars on the RID). That is, go for a ride.
2. place bike on center stand on firm and level ground (preferably while engine is running, do a 10 count, then turn off engine)
3. wait 10-15 minutes (no more, no less, and use a watch/clock)
4. look at the sight glass window
If the level is below the mid point, add some oil (it doesn't take much). If the level is above the mid point (and below the red ring) leave it be.
The operating temperature, center stand, and the wait time is critical. All three have to be obtained to get accurate readings. Going outside the parameters will result in some interesting oil levels (trust me, I've been down this road, and contacted BMW about this issue.)
The best thing one can do, to really figure out what is going on, is to do your own oil change, at least one time.
Drain the oil, and remove the oil filter. Replace with a fresh filter, and don't forget to put back the drain plug.
Pour in a known measured amount of oil (example: 3.5 quarts or 3 liters). Then follow the above steps to check the oil level.
Do it several times in a single day (actually the same day you changed your oil), and put the bike on the center stand at the same spot (say where you generally park your bike) and for grins and giggles, try it with the front tire off the ground, and the front tire touching the ground. Look at the oil level make a mental note of the average level (you will notice it is rather consistant)
But the key factors are: Engine temp, center stand on level ground, 10-15 minute wait. If you go outside of these parameters, all bets are OFF!! You will get varying levels in the sight glass. That is, putting it on the side stand, then center stand, not waiting long enough, waiting to long (overnight), etc.
