Morning folks.
I have recently awoken my 1150GS from a 3 year snooze, got it MOT'd and it still rides perfectly. However, the oil pressure warning light does not work with ignition on and engine off.
What I've checked so far:
Swapped the bulb for a known good one. No change.
Checked the voltage in the bulb holder with ignition on and engine off. 9.5 volts. Bulb still not illuminated.
Checked voltage of main beam bulb holder with ignition on and engine off. 9.5 volts. Bulb illuminated when main beam switch on.
It does seem odd that the contacts in the bulb holder are registering 9.5 volts without the bulb lighting up.
I've not yet traced the wiring to check for visible faults (I will when the tank isn't full of fuel). Before I do, I would like to ask the forum if this could just be a faulty pressure sensor?
Thoughts?
Regards
RobC
Thoughts?
Regards
RobC
