Oiling chain on 1290 SAS
The aim of lubing the chain is to get the lubrication on and inside the rollers - not the side plates. Yes - they will go rusty in certain conditions, but wiping them with an oliy rag should suffice
How does the lube get past the X rings?
I doesnt but if the chain is not lubed and the rollers ( for want of a better word) are dragging the X or O rings that are actually very thin or fine get dragged out of position and then the chain is fecked
That is my understanding any way
I've read that the X/O rings can overheat and fail if they dry out.
Views on this differ, but personally, I like to see my chain clean and lightly oiled. None of that sticky grease stuff that picks up grit.
Christ, if you thought this thread was bad, can you imagine it in the WC section if GS's had chains................................ :D
Andres
Andres
Wot! I can take off my oiler from my WC? but it looks so sparkly there..........
