brassmonkey001
I should change this
That's one way of doing it I 'spose
I was going to suggest that an 8gig card to fit your camera will set you back about 18 quid (for a bog standard SD card plus a reader) or a micro SD card and adaptor plus a card reader from the same place and price- you could transfer everything onto that card, move it across to the new machine then use the card afterwards in your camera
Even cheaper, a bog standard 8gb USB drive would be under £14 and would give you the same result....plug it in, cut and paste everything across, plug the card in the new machine and job done
Shughie's right...if you attempt to upload and download all of it across, you could be online for weeks and weeks messing around
I've got a 2Gb card, shoved that into the card reader but it pops up with a "File sharing could not be enabled." box so I don't know how I can move the files I want onto the card.
