OPNSense with SNORT / Suricata hardware search
sparkplug
Landlord, retired.
second from the left, third from the right
My current router/firewall threw a bit of a tantrum over the last few days and I've managed to bring it back to life, but it reminded me that the hardware is now nearly 8 years old and I should be looking into replacing it.
I do quite like the sound of OPNSense but definitely want IPS/IDS which is going to increase the required spec of the hardware to run it on.
Looking at Protectli - they recommend their FW6 series for that - but I don't really want or need 6 ports. I currently only use two.
Just wondering if anyone else has a similar setup and what hardware you used or would recommend?
What is your current bandwidth?
I have used Untangle NGFW for a number of years now, it's now known as Arista Edge Threat Management NGFW.
I have this running on a 4 port mini PC with an Intel Celeron J1900 & 8GB RAM sitting at the edge of a 330 / 50 FTTP connection. There's around 25 devices active at any one time, including various servers (web, mail, Plex etc)
I don't have IPS / IDS running on the router, but I do have Web Filter, Virus Blocker, Spam Blocker, Phish Blocker, Web Cache, Application Control, Firewall, Ad Blocker & OpenVPN Server running on it.
The hardware handles this all without any trouble, but I do know that adding IPS / IDS in to the mix would cause a significant load increase
200/20 Mbps - although it's far in excess of what I need on the dl (but it's nice to have the extra ul when submitting artwork which I still do for a handful of old clients)
Funnily enough I know quite a lot of the guys at Untangle as some moved from my old company when it was acquired (in a disastrous way. All 200 of the developers walked out on the same day with no jobs to go to rather than work for newco :D)
It's good kit by all accounts but I like the idea of going open source to avoid falling into the subscription trap.
Control freak? Yeah, maybe a little...
I've also got a mail server sitting behind it but not really anything more (Synology doing remote off site backups)
Because of its placement in the house I'm really looking for something fanless.
I asked over on the OPNSense forums and have had silence from them on the HW question :D
Currently looking at the Protectli FW6D which has an i5 8250U and you can spec the RAM/SSD. I reckon 8GB RAM should be plenty and a 120G SSD is overkill, but it's only a couple of € more.
All comes in at €571 delivered which probably isn't too bad considering. They'll even pre-install OPNSense free!
Mulling it over for a few days to see if I can find a better alternative before pulling the trigger.
The mini PC I use is fanless
It originally came with a SATA to SD Card adapter with something like an 8GB SD Card (urgh, gross)
Pretty quickly swapped that out to something more reliable, a 120GB m2 SATA from what I can remember.
It’s been ages since I have had to worry about it.
It’s been up for just over 5 months currently, although I am planning a rebuild of it soon. It was running on 4GB of RAM when I first built it, since then I have upped that to 8GB & even though it recognises the 8GB the installation is optimised to run on 4. The advice is to just reinstall with the 8 from scratch, so I really should get round to doing that
I currently pay $50 a year for the Home License from Untangle.
I very recently nearly switched over to OPNSense, as I liked the idea of going open source & not having to pay for an annual license.
That was until I discovered that in order to continue blocking specific devices access to specific web sites during specific time frames, I would need to pay for a licensed add on (Zenarmour) at $100 a year :blast
I’m so glad I had the sense to have a play in a VM set up before rebuilding my router proper & then discovering this
The devil is always in the detail :D
I had a quick skim over Zenarmour but to be honest my brain was Firewalled out at that point.... will have a proper look again another time.
I was also looking at putting Zabbix on a Pi (inexpensive experiment) but not sure that I 'need' it really. Might be fun.
I also just thought that it would be nice to have some form of AV on OPNSense (if it isn't built in already - I haven't looked yet) so that's yet another detail to go shopping for...
I really should bite the bullet and do something like a CCNA or Comptia A+ because there are some massive holes in my self taught knowledge.
It just comes down to time though.
From what I could tell, Zenarmour is free as a blanket coverage for all devices on your network, but if you want different rules for different devices and / or at different times etc then you need to pay for additional licensing.
I’ve seen bits about Zabbix but quickly decided that it wasn’t something that I really need, as you say.
You can configure ClamAV to work with OPNSense as an add on / plugin
All of my knowledge has been self taught over the years. I have found this to be the best way for me as I can focus on learning exactly what I need to & skip anything that isn’t relevant.
I have an old HP Z800 workstation running ESXi handling ~10 VMs. If I want to mess around with something new I spin up a new VM & play around. If I mess things up there’s no drama as I can just scrap the VM & start again :thumb2
sweet!
I like ClamAV - thank you!
I know sig based scanning is 'old hat' these days but until there's a 'home' version of stuff like Crowdstrike then it's just another bit of filtering which isn't going to hurt.
We used to sell our firewall with dual AV (McAfee & Sophos initially then we binned the hateful McAfee and brought in BitDefender) because even when sig based stuff wasn't old hat, it wasn't always reliable.
