Woooodentop
Can you plug an Optimate charger directly into the auxiliary socket on a 06GS to charge the battery.
Cheers:
Cheers:
Cheers:
(I use the same socket to power my GPS, by the way. This achieves the simultaneous demise of two feathered vertebrates with a single 14 lb weight.)
Optimate sockets should definitely be on the LHS. Putting it on the RHS will cause all sorts of problems; EWS ring problems have been traced back to this, also speedo/ABS sensor failures.
I have my flying socket on the RHS, but that's OK because I have a Ctek charger.
Am I right in thinking that if you hard wire the Optimate connection directly to the battery then there is not any problem in using the Optimate charger even on a Canbus wired system???
No, no. Never the LHS.
If in doubt, remember the little numonic*, Royal Horticultural Society.
*Nor pneumonic, that'll definitely kill you.
Would anyone recommend Optimating one of those clever ODYSSEY Batteries ?
Considering they are spposed to be so Super Duper ??
