Can I plug an Optimate into the accessories plug under the seat? Or must I connect straight to the battery? Still haven't got to grips with canbus
Thanks in advance....
OldCroc
OldCroc
Need to connect straight to the battery. Best bet, is to wire in a permanent waterproof lead with the end poking out from under the seat.
Also once you have it wired in you can also get optimate connectors and use the lead as a direct power source for any toys as well as your aux socket![]()
Remembering to fit a correctly rated in line fuse (5A, if it was me) to prevent all kinds of potential 'issues'
Where can male Optimate conectors be purchased?
Alan R
Canbus won't allow it. you need to direct connect to the battery.
AlanR
Wrong :| Canbus does allow it if you have a recent software version.
Mine is currently plugged in to the socket and cycles without any issues.
Always amazes me how many different wrong answers you get to questions on this forum!
