Wooly Bugger
Hi All
New to this forum. It looks great!
I need some advice please:
2007 model, 26 000 km's, moderate riding
lots of black smoke at cold start
engine hunts at idling speed
slight ping at 130kph
throttle response checked and reads equal
BMW diagnostics reckon the mixture is LEAN?
RHS spark plug pitch black
HIGH fuel consumption.......
off to the workshop!
10 days later the scenario as follows
swopped out all the vitals and re-mapped fuel settings (solved the start-up problems)
checked lambda sensors and swopped them over: no difference
replaced injectors: no difference
checked FPR: works spot-on
no damage to RHS piston/rings/valves
still smokes at 5000-7000rpm
what could it be? is the engine perhaps sucking in air through a leak some where? AFR settings as per BMW standards.
Quo Vadis?
Thank you
Wooly Bugger from sunny RSA
Quo Vadis?
Thank you
