Oxford Plug-It XL Tyre Repair Kit.
limited to 5A and well documented on here. Tyre pumps are well over that 5A, especially the inrush current when turned on. On my R1200RS I fitted a 12V socket using a piggy back fuse on one of the real fuses under the seat.
Yeah I found that out afterwards with a bit of googling, never had an issue on previous bikes, sorted now though with a battery operated one.
my Yamahas were the same but a PITA as they had real fuses under fairing panels, Tracer & Super Tenere. Like you I did not RTFM so found out the hard way. My pump has croc clips which is fine for the current V85 with easily accessed battery under the seat. For bikes with batteries hidden under panels, I'm a big fan of SAE fly leads for charging and powering pumps etc.
Looks good.
The only thing that is missing Martin is a pair of pointed nosed pliers to remove the offending item
I also carry a pair of side cutters because in the past I've had problems getting enough purchase on the offending screw with long nosed pliers to remove it. The sidecutters can bite into the screw giving you a better grip on the little bu88er (being careful not to grip too hard so you cut through it).
I also have an airman pump and connect it as per @wessie above. The flying lead also doubles up (or should that be tripples) for my optimate 4 and my Keiss heated gillet. The CO2 cannisters are smaller, but won't inflate your tyre fully so you then have to find a garage, plus if the plug doesn't work.1st time you can then run out of canisters if you're unlucky.
