Oxford version of Fuseblock
KMD
North Yorkshire
By and large I like Oxford bike products, they are generally fit for purpose and cost less than ‘big brand’ name kit. I have a Fuseblock fitted to one of my bikes and was looking for a similar solution for the other bike when I came across this :
Has anyone here used one and care to comment on them please ?
I have an Aliexpress copy of that on my Voge 300, it works a treat, I've even got the Oxford heated grips running through it with no issues.
Sent from my SM-S921B using Tapatalk
  • Like
Reactions: KMD
Does the unit itself have to be connected to a switched live, or directly to the battery?
Both. There’s a permanent live and neutral, with a third wire that takes a switched live feed to power the unit up.
Thanks for the link, my Fuzeblock is silly money in comparison.
  • Like
Reactions: KMD
Permanent live and neutral with battery connectors, and the switched live..IMG_0088.jpeg
No spaces provided for writing on the lid which feed is for which accessory, as the Fuseblock does, but I do like the pinch to remove lid, where the Fuseblock is two very easy to lose screws.IMG_0089.jpeg
Two ‘straight through’ slots for attaching with cable ties (two included) and also a piece of double sided adhesive tape so securing it in place shouldn’t be too much of a problem.IMG_0090.jpeg
All things considered, at £24 I’m satisfied. Only four power outlets, where a Fuseblock has five or six I can’t recall, but in truth I’ve only ever used four so it should be fine.
Looks good. A very decent alternative to the Fuseblock and Thunderbox. Ta for posting. (y)
  • Like
Reactions: KMD
My bike has a/the Fuzeblock in a very awkward position (note the spelling). I replaced the screws with thumbscrews, they are bigger and easier (on my bike at least) to access. Beware the Fuzeblock I have is American made therefore the threads are not metric. I found this out by using thumbscrews from the back of an old computer, I think 6_32.
tom
Ive been using one on the Himy 450 for about 3 months. Good piece of kit for the money. My only gripe is the 5 amp limit per fuse but I knew that when I was buying it
  • Like
Reactions: KMD
Ive the same unit, but not branded Oxford. Ive mounted it under the seat (in front of the fuel tank) on my 1150.
  • Like
Reactions: KMD
Is that only limited because of the 5 amp fuses under the cover?? The cabling looks more than enough if only using 1 or 2 devices and the rest remain unused.
