Paddock stand
pitrat101
Cheshire
Any recommendations for a good paddock stand for 2024 1250rs?
i used the warrior single arm stand on my last bike from e bay you need to know the spindle size to go through your back wheel dont use one on my 1250 rs having a centre stand
Just rear, so i can safely get bike on ABBA skylift, using block of wood a moment and a bit dodgy.
I have one similar to this I bought for my 1st 1200GS in 2016. It also fits my RS too and raises the rear wheel higher than it did on the GS (or it seems to) due to the different front wheel sizes - 19" vs 17". I don't use the front paddock stand I bought on the RS as that takes quite a bit of effort/again brings the front wheel.off the ground quite a bit due to it's diameter and the bottom of the fork stansion being lower to the ground that the GS'
Here's one like the rear I have. Slots through the hole on the FD hub and is safer than the bobbin types as you can slot it into place while the bike's on it's sidestand, then push down on the handle of the paddock stand to bring the bike upright. Taking it off simply reverse the process remembering to put the sidestand down first of course!
MPW Race Dept - Motorcycle Single Sided Rear Paddock Stand with 53.0mm Pin - MPW https://share.google/mcHscQqvWiLVCSIpp
Here's one like I have for the front
