Pairing 660 with HTC Phone via Bluetooth
Grey Beard
Hamburg, Germany
I have a Zumo 660 flashed to the latest firmware a few days ago and have paired that with a Schuberth Rider Communications System via BlueTooth (also firmware upgraded to latest available).
So far, so good.
I am trying to pair my Zumo with an HTC HD2 (Windows 6.5 phone), but the phone cannot see any Bluetooth devices and the Zumo can't see the HTC phone. I guess the Zumo Bluetooth is OK, as it pairs with the Schuberth.
Anyone tried this with this phone (it is Bluetooth 2.1 +EDR & A2DP compliant according to the specs). Are these the latest in Bluetooth, or should I be looking for a HD2 firmware upgrade also?
Ideas? Thanks
Grey Beard
Read your post i know its not the windows phone same as yours but tried my htc desire, but for what its worth it found it ok, . hope you manage it.
Nozza
Nozza
Thanks Nozza. I eventually got the pairing to work, but had not made any changes. Must be sensitive to relative positions of the Bluetooth antenna, but Zumo pairing with the Schuberth SRC was much easier.
I was going to try and flash upgrade the phone ROM, but Win 7 and a USB connection, will not let me see the phone, unless I have the memory card in the phone and then it is only the memory card and not the actual phone that I can see. I would need to back up the phone first prior to flashing the ROM. Flaky Win 7!!
Grey Beard
Similar threads
Replies
4
Views
1,342
hubarb spong
