Pairing two Sena SMH10 to one Zumo 550
llotse
Beverley, East Yorkshire
I have tried a search but no joy. Is it possible to connect two Sena SMH10 to the same GPS so my Mrs can hear it too? Do I need anything extra to do it such as the SM10 to achieve this, looks like I might :nenau
Any help appreciated, have an Autocom on our own bike but going to South Africa and renting later this year :bounce1
You cannot connect two units to the Zumo.............. If you have the latest software installed on the Sena's, you can connect Sena 1 to the Zumo, and Sena number 2 can listen to the what the first Sena is connected to.................... Apparently.
Must give it a go.
I'd be quite surprised if this is possible. Daisy chaining the SMH10 is no problem to another SMh10 and then onto another with all being able to hear each other but I doubt if a source to an SMH10 would follow the chain. Would be good to know, might try to do this next time I'm out with similarly equipped helmet.
It would, if possible also imply that multiples could listen to same music..
Scrub that!, can't see it working as the SMH10 cascades the different inputs by different priorities, can't remember exact but the phone overrides the intercom and the GPS will do too (just can't remember if the GPS is higher priority than phone or not - don't think it is)
Phone has the highest priority, but you can change it.
you have to close the bike to bike connection if you want to hear the sat nav instructions.
Gargy is right you cannot connect two senas to one zumo unfortunately ...
saying that, the SMH10 are the best comms Ive had by far :thumb2
