Pan European pegs on 1150
raginmund
Lancashire
istr Timolgra saying that the riders pegs from the Pan fit the 1150, but I can't find it now.
I was going to ask; ST1100 pegs or ST1300? Or does it not matter?
Good tip about the Pan pegs. I fitted some 1100S pegs on mine which made a lot of difference for about £15. You have to play with the springs slightly. Also K prgs will fit if you trim them very slighly.
Hi, what Pan european pegs fit? the1100 or the St1300? would be interested myself. Are there any pictures of them fitted? thanks, Dave
Wrigsby, what's the advantage of the 1000S pegs?
I'd like mine to be wider, primarily, for more movement on long trips and also to help weighting the pegs in corners. The existing ones are quite small.
I don't have a problem with height, as my legs are quite short.
Ah, wrong end o da stick:D I'm 6'6" and they were to do with height. Pan pegs are probably wide like the PC8 that I briefly had.
The original question of ST1100 or 1300 pegs.... I had a pair of ST1100 pegs on a couple of 1150's....
They'll need a spacer fitting, which is do-able with a bit of angle ally and a bench grinder ....Haven't got them now so difficult to explain easily The gap on the hangers is bigger than the actual ST1100 peg itself .
3.5 to 4mm thick is what you need.
Pivot pin is same diameter.
I'll have a set for sale in a couple of weeks if I can find them:blast
Neil
