Pannier rails for R80GS Basic
Mad Hatter
Ain, 01, France
I’ve posted in the wanted section but asking here as well as I know it’s where us airheaders tend to lurk most….
…..does anyone have a set of pannier rails for an R80GS Basic they’d be willing to part with? These are different to R80GS/R100GS
Many thanks
Many thanks
They are also different, though similar, to those for the R80 G/S. When the Basic was a current model Hepco and Becker were the only source I think.
I know Hepco and Becker make a set for the basic but they don’t fit the original BMW cases. BMW still list the OEM frames as available so I’m going to try ordering a set….
Alas no joy. The OEM frames are NLA from BMW. I’ve dropped siebenrock a note as suggested above
These are available from BMW but only in painted black and as individual parts not as a complete kit
Chrome ones are not available at all either as individual parts nor as a kit
The black frames that are available are :
46 54 2 300 021 - Case Holder Left - German Factory Stock - £158
46 54 2 317 408 - Case Holder Right - German Factory Stock - £113
You would also need to buy the fixings & fastenings but they are just standard nuts bolts and washers
That’s great if the parts are individually available. How were you able to check?
Spoke with my friendly parts department at my preferred UK BMW Motorrad dealer ;-)
They came back with :
Complete set of parts (both panner rails and rear rack)
46 54 2 317 421 Set Case Holders - No longer available
Individual parts :
46 54 2 300 021 Case Holder Left - German stock
46 54 2 317 408 Case Holder Right - German stock
46 54 2 317 535 Case Rod - no longer available
46 54 2 300 120 or 46 54 2 300 126 Baggage Rack - both no longer available
Individual parts :
You sir are a superstar. If I can get the two hoops it should be easy enough to fabricate the rest. Thanks very much for digging into that for me.
Just checked and here are the current stock levels :
46 54 2 300 021 - Case Holder Left - 51 in Germany
46 54 2 317 408 - Case Holder Right - 6 in Germany
Thanks for that. I’ve contacted the supplier I use here in France and they say there are also a couple more parts available (number 4 and number 5 below). Can anyone tell me what part number 5 is used for?
Where is it supposed to fit?
I’m really not sure
If it was me I’d be just getting the two pannier frames from BMW and then the Hepco & Becker rear rack , it might take a little bit fettling/adjustment to get them all to fit but I think the finished job would look good
I’m really not sure
Good news, I managed to find a NOS OEM rear rack to go with the pannier hoops that are still available from BMW so I’m all sorted. Many thanks for the help👍
