Paralever bearing removal
SCOTTY
Thorne S.Yorks
I am halfway through the job , have searched lots of posts but what i need to know is ,
do i use heat to remove the old bearings or knock them out cold ?:nenau
Easy to drift in and out cold. I use a bit of wood when I drift them in to protect the bearing from my hammer:) Just make sure to put them in the right way round, with the taper inwards
Cold will be fine.... light taps. If you belt them to hard they will lock.
