jeff smith Member UKGSer Subscriber Joined Nov 21, 2008 Messages 39 Reaction score 0 Location wales Jan 27, 2025 #1 R1200 GS. 2006 taken off cir-clip removed bolt and switch . Bearing /bush will rotate but cannot pull out . Any advice please. thanks
Santa-2512 Omnipotent one UKGSer Subscriber Joined Aug 3, 2016 Messages 14,181 Reaction score 3,661 Location North Pole Jan 28, 2025 #2 Always helpfull to add the month of production, they change things throughout the build year two types of fixing , with top hats or without sounds like the top hats are stuck, i cut mine of with a cold chisel and then replaced all FRAME AND MOUNTING PARTS Diagrams for BMW K25 (R 1200 GS) R 1200 GS 04 (0307,0317) | RealOEM.com BMW parts K25 (R 1200 GS) R 1200 GS 04 (0307,0317) Diagram Selection www.realoem.com
jeff smith Member UKGSer Subscriber Joined Nov 21, 2008 Messages 39 Reaction score 0 Location wales Feb 6, 2025 #3 Santa-2512 said: Always helpfull to add the month of production, they change things throughout the build year two types of fixing , with top hats or without sounds like the top hats are stuck, i cut mine of with a cold chisel and then replaced all FRAME AND MOUNTING PARTS Diagrams for BMW K25 (R 1200 GS) R 1200 GS 04 (0307,0317) | RealOEM.com BMW parts K25 (R 1200 GS) R 1200 GS 04 (0307,0317) Diagram Selection www.realoem.com Click to expand... thanks for the reply its the steel bearing I cannot remove it rotates but must be off set due to wear still scratching my head
Santa-2512 Omnipotent one UKGSer Subscriber Joined Aug 3, 2016 Messages 14,181 Reaction score 3,661 Location North Pole Feb 6, 2025 #4 jeff smith said: thanks for the reply its the steel bearing I cannot remove it rotates but must be off set due to wear still scratching my head Click to expand... Which part no, it been some time, but if you can point out which bit I'll have a chat to my friend who did it with me
jeff smith Member UKGSer Subscriber Joined Nov 21, 2008 Messages 39 Reaction score 0 Location wales Feb 8, 2025 #5 FRA83131-1 Associated BMW part 46527683131 I may hacksaw the stand off and replace it if im unsucessful next week . thanks
Santa-2512 Omnipotent one UKGSer Subscriber Joined Aug 3, 2016 Messages 14,181 Reaction score 3,661 Location North Pole Feb 9, 2025 #6 The bush goes through the frame, it pushes in / out in a vertical or horizontal direction , it does not get pushed in / out like a pistion If that makes sense , some say it has a hook hole in it to aid removal, bit i think i just levered mine out The top hats will nip the bush if i recall, I had replacements just in case
Santa-2512 Omnipotent one UKGSer Subscriber Joined Aug 3, 2016 Messages 14,181 Reaction score 3,661 Location North Pole Feb 10, 2025 #7 Ignore the above, I finally got into the repair data, Once the bolt is removed, the side stand will pull off What will be stopping will be the top hats, or crud / build up which makes the gap to the other faces to small , I treated the top hats as a consumable, and snipped them/ cut them off Once off the side stand can be levered off and the bearing drifted out.
