beakmeister
Just stripped the side stand off my 1150 as it seems to lean over too much due to play in the pivot. The pivot bolt is not worn as the thread section is all the same diameter, but there is a lot of play inside the small bush, is this normal as the bush appears to be surface hardened inside????
I was thinking of turning a new bush that is just a tad better fit, but your solution is much easier, thanks
