Paralever bearings 1100 1150
Old Codger
Mid Hants
Anyone found an alternative source for the tapered Paralever Bearings
for the 1100 1150 other than BM ?
Thanks for that
It was bearings not bushings I was searching for
Those rubber Chicken bushes seem plagued with failures and problems which have surfaced via Adv Rider Plus they are not a cheap alternative
I went with the OEM bearings myself.
Yup
I went with the OEM myself
But at over £20 plus the Vodka and Tonic each you have to wonder if any of the bearing manufacturers have alternatives of the same spec
With SKF and the specific part no so far I seem to have drawn a blank
Looks like BWM have it sewn up may have been a special order from SKF
Research continues
I would have thought less than £60 for the pair was a reasonable price for something that should last a long time. At least going OEM you know you have the right ones.
If you want some of my vast inexperience fitting some I can help you mate.:beerjug:
