Wanted Parts cleaner
You'll also need some cleaner, i used
Carbsonic ultrasonic cleaner for carburettors ( the red stuff) , not cheap, but you dilute it and it goes a long way
Also the instructions ar'nt to clear, if you want a hot clean, you have to heat the tank first and then set the fizz time
otherwise its fizzing and heating at the same time, and the tank may not get to the temp you want
I got my zorst flap in my unit with no problems
I use Flash in mine. Not much, just a couple of drops.
Then run it for ten minutes or so to degas the water, that seems to help. I guess you could just run it for longer the first time with new water in.
If the op has bought the same as i did, it has a degass setting i did the degass then ran it for 30 mins cold 60 hot 30 cold for a few days
