Referring to the museum
This is where i used to work , last in 2000.
The place was a processing plant .
From the top level , the meal rode along a drag line into a hopper.
Next down, the hopper bottoms were operated by a pull slide which had a skirt sack which you tied up with a rope.
The top of the pots had a very heavy door with drop down bolts that held the
top sealed under pressure.
This was held on a swinging arm that you grabbed with , a solid brass walking stick type tool.
You can just see the doors on the right of the picture , next to the "full silo sign"
Below the hopper was the pot , a giant kettle , that boiled the meal with a petrol water mix called hexane.
This stuff was bloody volatile , we had to use brass wrenches, and hammers.
No naked flames were allowed , all light fixings , were hard wired in.
Even pulling gear had to be done by hand , block and tackle were used to shift 20 ton water filters outside the plant , this took ages .
If the plant was ever to go BANG , it would of taken selby with it (which isnt a bad idea
Bear in mind it was bloody hot up there with huge boiling kettle below you.
The ground level was the drag line and the bottom of the kettle.
When a whistle was blown , and the guy above tapped his crook (told yer it was ancient
) you opend the bottom door , and the meal would fall out.
After a while the meal stopped flowing. So you had to use a long 10 foot pole with a scraper blade fitted on the end.
Inside the bottom of the pot/kettle is a bloody giant stirring wheel , this didnt stop untill you pulled a leaver , "crash clutch". You also had to time the rotation of the stirring wheel so you missed the arms going around , or you would snap your scraper pole.
All the boiled meal would drop on to the drag line , and the process would start all over again.
Behind the pots , water and petrol was managed by a series on valves , bloody complicated , to work out as they were only colour coded .
We worked in 12 hour shifts, 3 shift rotation.
More old machinery...
Next door was the old machine shop , all run by bet drive and pulley's
This was the where the giant winding wheel ran the main shaft to the processing plant .
The wheel was 20 foot tall and was run by an old 1920s steam powered motor
(i think , D6 will correct me) From the motor to the wheel are several thick leather ropes that drive on to the main shaft.
More of the old place where the giant crackers used to crush up shea nut , and other meals , to a pulp.
Not much in line of guards , n if ye caught yer hand in the cracker , you followed it ...nowt would stop it.
Also belt driven ....
The pic above is the belt drive to the main shafts and the cracker
Below there is a pit , which was always full of old rotten meal , rat piss, and 4inch cockroaches
On a friday this pit had to be dug out , not a fun job at all
I worked at the Extraction plant till 2000, untill the management decided to make us all redundant , and close the place down
I started working as a cleaner , moved to the bottom floor, then to the top floor, eventually i moved with the top men round the back operating the valves.
This place was stuck in the 1920 , like some of the workers , ha,ha
ugg
