PD Headlight
oldenoughtoknowbetter
Hitcham Suffolk
I've acquired a UK spec headlight for my German import PD Classic. The headlight seems to fit into a plastic frame by 2 adjuster screws plus a pivot point. Before I take the thing apart (when the weather gets warmer!) do I need to also buy a UK spec plastic frame or will the existing frame take the UK light?
The adjusters give you left/right and up/down adjustment so it shouldn't matter, however before you go anywhere near those adjusters but a couple of replacements (part number LIA69833 from Motorworks at £1.49 each) they go brittle with age and will break when you touch them.
