Pellicase and Autocom on a 16 build LC TE
I had a similar issue looking for somewhere to mount my Autocom when I bought the GS with all those extra units. In the end I found a spot for it on a shelf in my garage. Although I was always impressed with the Autocom in its day, I have found nothing my Freecom does less well than it did and I really don't miss the wires. I do, however, admire the OP's efforts!
And if you have the BMW alarm fitted you can kiss goodbye to all the space in the void under the rack.
I undid the 2 screws securing the TPS monitor. Brought it forward and laid to one side of the leany ABS gadget. The SPA then slid into the TPS unit place but pulled as far forward as possible. Bluetooth unit slid on its side to the side of the SPA unit. Everything wrapped in bubblewrap to try and give some protection. its not good but its the best you can do.
Any Pics?
The aluminium box doesn't fit under the GSA rack:blast
Hi all, I know this is an old thread, but I'm taking my daughter away on the bike this weekend for the first time and so I have dusted off my Autocom logic and was going to install it on the bike. I have been using the BMW Bluetooth unit on my helmet but its stopped charging and I don't have a second one for my daughter regardless.
Anyway, I was just wondering where you guys are pulling the switched live from? The other option is to just wire it go the battery with an on/off switch!
On the 16 GS took the switched live from the red wire with blue stripe in the 2 fuse block under rider seat, if you don’t want to cut into the wire you can now buy a dummy fuse block holder with pig tail that just plugs in.
https://www.halfords.com/technology/car-audio/head-unit-accessories/autoleads-blade-add-a-fuse
Just check it’s the right dimension blades
