TasGS
Hi all,
I'm attempting to remove the final drive pivot pins, the LHS pin came off very easily(was heated), nut required a bit of force but the pin was only slightly more than finger tight, however I couldn't see any sign of loctite on the threads...
The RHS on the other hand is being stubborn, I've tried removing it cold(incase it had different loctite), aswell as hot(water sizzles when dripped onto pin). I'm just wondering how much force do you need to apply to undo the pins? With the LHS coming undone so easily and stories of stripped threads I've been fairly tentative so far so thought I would ask before I break something...
Thanks in advance!
Edit : Bike is a 2001 1150gs ~100,000ks
Thanks in advance!
