Bendy toy
Ive had a TwinMax electronic throttle balancer for some months but only just got around to using it.
The on/off switch is daft you can easily leave it switched on and flatten the 9V battery. But in use its great. Set it to minimum sensitivity and see how the needle settles. Tweak the throttle cable up on low reading side and continue until the needle is at midpoint on max sensitivity. You may need to tweak both sides.
I unplugged the idle stepper motors making it tricky to start but no big deal. Once balanced reconnect the steppers and job done.
Unplug the 9V battery before putting back into the cupboard.
