PMR radio with Bluetooth connectivity
ebbo
York
Just a little more info from the "Bluetooth functionality pdf"
• While the Bluetooth headset and the radio do not require any cable connection, it is now possible to mount the radio and external PTT key on the motor bike - this ensures a better communication range, since the radio is no more operated from a pocket in your jacket. A free radiating antenna can extend the communication range under optimized conditions up to 4-6 km.
• The automatic voice switching (VOX-function) of the radio can also be used in Bluetooth mode (if the headset ensures sufficient noise canceling). Some high-end motor bike helmets may allow VOX operation at moderate speed. However, we recommend to use manual PTT switching for 2-way motor bike radio communication. Only PTT operation allows clear and undisturbed communication at high speed situations. A waterproof PTT key is supplied with the radio!
• The Bluetooth Module of 445 BT contains the chipset of our BPA 100 Bluetooth adaptor and can be connected to almost all standard BT-headsets, which are sold for use with cellular phones.
• The additional charging socket allows recharging of the batteries even during operation of the radio.
