Well I took the new 80 m0n0 out to get her boots muddy last weekend, It was peeing down but after hiding for a while in the local bikers cafe ( with all the guys who had come in their cars) I went out to play. got nice and muddy and just managed to keep it shiny side up. wrong tyres fitted. Anyway the engine never missed a beat. got home and is my wont, a quick spray with flash and a good hosing down( not a pressure wash) put her away and sat5 down to a nice bit of roast beef....
Now the real reason for writing this.. couple of days later started her up (the g/s) as usual running sweet until she warmed up a bit and I closed the choke. Pop ...Bang ....rough as an old boot then stopped and refused to start. checked all the usual, spark and fuel. No sign of water in either the tank or the bowels. Left alone till next day, tried again and exactly the same. started off the button, sweet then popping and banging. left alonhe with battery charger on and try again next day. still the same. more bits checked again including air filter. Today I started her again and would you believe it, perfect and stayed that way...... I did however notice that the little cap on the top of the right hand carb is missing. there is a rubber bit in there but I dont know if the cap goes over that or whether someone has stuffed this in instead. I suspect that water has got into the vacum chamber then cocked up the running on that carb.........Now then can anyone answer the above and also can the little metal cap be obtained or is it a new carb top.
