Portable welder wanted
PW Cymru
Moderator
Moderator
Nr Cardiff
Anybody available local to Cardiff with a portable welder and the skills to use it. I've got a small crack in the footrest hanger gusset on the RS and would like to weld it while I've got good access.
Must be a common break that, my nephews R100 had broken in exactly the same place! welded up no problem,
Hi ebbo,
Probably caused by the bike having an off on the left at some time as the exhaust support at the back of the hanger was slightly bent, bit of heat and a hammer sorted that out.
Al BigAl has kindly offered his skills and equipment so should have it sorted soon.
