Well I finally got around to removing the heads on the R80. I have long suspected the top front cylinder stud on the left side to have a problem, as it appeared to have been cut at the end just after the rocker.
As the bike was running fine, I decided at the time not to tempt fate just yet.
I have new cylinders to go on so they had to come off now. As far as I can see, its a previous repair. The stud is definitely cleaner than the other three and has far more threads proud of the crank case than the others. It looks like its been turned down to a thinner diameter, and maybe not the correct stud. The thread on the other end has been cut short as you can see in the pics.
I have no idea how much thread is actually in the hole and engaging to hold the stud in the case. The rockers seemed to get oil and the bike ran just fine.
I cant see any oil galleys around the stud, or where it would feed from the back, but then again i dont know what im looking for.
Should I just leave the repair in place and hope that it stays in when i torque the heads back on, or remove it and see whats going on? I have a complete set of replacement studs in the spares box.
Anyway, have some pics. Likely to explain things far more clearly than me wittering on:
On the plus side, the valves look in decent shape (i think) showing no signs of creeping into the head. Feel free to tell me otherwise
