elbowsg450x
When i stop the bike while out on a ride for a few minutes it is really hard to start.
It seems to happen 2 or 3 times each time i ride it and its getting to be a pain as a few times it has caused me to become separated from the group in the middle of nowhere.
sometimes it seems to try and star, others it seems like the starter isnt even trying. after about 5 goes the battery is almost flat so its a real problem with no kickstart. this is the thing that worries me most as its impossible to bump start a bike in snow etc
i thought it may be a kill switch fault as the first time it happened i hit the red button a few times and re tried the starter and it worked. i have taken the switch apart and cleaned it with electrical lubricant but it still does it every now and then.
It starts easily when cold.
i have contacted the dealer as my sides tand snapped off yesterday while on a trail leaving a sheared bolt inside the frame. bmw are getting the pleasure of extracting this as the bike was bought brand new in november.
i told them about the starting problem but they didnt seem to know any common fault what may cause this. i want them to run the diagnostics check to see if there is any record of this.
anyone had similar issues?
