i am having problems powering my zumo 220 from the headstock outlet and need to tap the collective genius we have here, so.....
the 220 lead is fitted with the bmw fitting as described in the "make a lead" thread, and works fine however now and again it says external power is lost and the unit will switch off. now i know the gps unit is ok as it works fine when connected straight to the battery, so does anyone know why this happens when wired into the headstock? and is there an easy solution (apart from just wiring to the battery!!) to this problem
thank for your time
cheers
mike
thank for your time
cheers
mike
