Project XChallenge
All the parts for powder coating sorted and dropped off .....
Bags of parts all cleaned , refurbished , labelled up and ready for re-assembly
It's certainly in bits now.. :D
But I spose there are far less parts than most bikes, with it being a rather basic design.. ;)
Got a few little jobs done today - Sprocket carrier bearings removed and front and rear brake calipers stripped , cleaned and rebuilt with new seals
Replacement wheel bearings (Front & Rear) are:
20X42X12 so SKF explorer 6004-2RSH/C3
Sprocket carrier/cush drive are incorrectly listed on BMW fiche , they list 20X42X12 and they are in fact 25X47X12 so SKF explorer 6005-2RSH/C3
Enjoying the strip & rebuild......:thumb
Ready for my XC..
Progressive springs.
Once it warns up, sadly busted bones & cold garages ain't fun.. :(
Ready for my XC..
You need a thin spanner to hold the locknut under the top cap as it needs to fit between the spring coils . Also loosen the top cap whilst the forks are in the fork bridge on the bike unless you have a spare bridge to use on the bench to clamp the fork leg
Great help thanks sire..
Must admit I haven't looked into fitting them yet.
I do have a workshop disc, but haven't loaded it into puter yet as all the jobs I have done I did on my last one.
( that I should of kept ) :blast
:thumb
:thumb
19mm spanner btw - I used a spare pedal bike cone spanner and filed it to correct size..
Well - I'm glad that's done : re-wrapped the wiring loom with cloth loom tape and dielectric greased all of the connectors . All ready to go back on now - just need the frame back from the powder coaters and re-assembley can begin......
Proper job. ( in a West Country accent ) ;)
Sprocket carrier bearings and seal fitted and nice new shiny fork guards fitted . At a halt now until I get the frame back from Powder coating - hopefully Tuesday . Still got the wheels with Roy Thursby being sorted , all the panels at Saragon Custom Painting being treated to a new colour scheme and the seat at Saddlecraft being recovered and a gel insert added
We're did sire get the fork guards from, if I may ask..?
If I may offer my two penneth .... keep the fork clamped in the lower yoke, but slacken the top clamping bolts off, when you try to undo the alloy top nut! Otherwise the top clamp, if still tight, holds the top nut sufficiently to stop you loosening it, resulting in buggering the nice alloy top nut :eek:
Don't ask me how I know .... :blast
Yup - i agree - on my first G650 XMoto - I did the same and had to replace one very expensive top cover
Good point gents..
Thankee kindly..
Just got the parts from Powder coating back - very pleased with them . Just need to remove the masking tape , blanking plugs etc and tap out all of the holes , clean up bores then I can start on re-assembley.....
