Pump Bypass lead
stick
Lord Lytteltons Door Mat
I am making a bypass lead but my electrical knowlage is bad - can someone tell me which wire goes to which ie ; i have a spare blue plug which goes direct to the pump - it has a yellow and a blue wire - which one is power and which one is neg as i will be running it direct to the battry (fused) any advice would be appreciated as struggling !
Thanks:comfort
Thanks:comfort
Should all be in HERE:thumb
my local bmw dealer said they had a big box of old FPCs, working but changed under the recent, ahem, "quality enhancement" program.
might be worth asking if you could just have one as a spare if you're on good terms with them :nenau
Power supply
Thanks for the link - this link was useful but did not say which wire was which - but with a little messing (should have done this first) managed to find the correct wire and did a test run - worked fine - again thanks for all the help - could not ask for more :thumb:bounce1:roll:roll:bounce1
Not gonna put us out of our misery/post the answer for the benefit of others ??:nenau
As far as I know, the pump is non-directional, so it makes no difference which way round the wires go. It will always blow.... not suck (or visa-versa) if you see what I mean.
PS If you ever fill the tank with a load of diesel, you can disconnect the fuel line and use the work-around to simply drive the pump to empty the tank.
Wire
Power is the yellow wire - sorry for not finishing the thread but have been away.
As wapping said it may not make a difference with the wire colours but at least i know now so may help other 'no so good bike electricians':thumb
